fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun Mar 16, 2003 3:46 am
yea but smoking even when the car is OFF? thats a little weird... I mean, I know white = coolant, but you're not burning anything when the car is off...
the white could be steam maybe? maybe you're overheating and your temp is broken? you could be overheating because too much coolant has been burnt and there is nothing circulating round your engine? check the coolant container-- is it empty? haha... uhmm also check to see how the "smoke" smells... coolant has a sweet-ish smell to it.
EDIT: also to narrow things down, have someone start the car while you look in the radiator (cap off, obviously), and in the coolant resovior (sp?). bubbles in either place can point to a headgasket leak.
