Zoltan11 »
https://forums.nicoclub.com/zoltan11-u167230.html
Mon Mar 14, 2011 7:19 pm
Ses light back on after several thousand miles of being off during the cold months here in Colorado. I started this topic several months back when it was still quite warm. (above 45 F. ) My SES light turned itself off once it got below 40 consistently. It remaind off as long as it stayed cold. It turned itself on again when there was an unusually warm week. Then it turned itself off again once it got cold again. It's been above 45 regularly for the past week and now the light is back on. I should mention that I drive 500 miles a week for work. Part city part highway. The code seems to be triggered when coasting down to lower speeds from highway speed when it's been warm for at least a few days. Since temp seems to be a big factor should I be looking into the temp sensor instead of the common carbon build up in the egr tubes? I have read a number of other posts saying they replaced and or cleaned a lot of the egr system components only to have the same code pop up again. I even read that one guy did everything only to find out the problem was only a leak or something in the air box. Anyone got any thoughts?
Thanks
