Cheap OBD-II, let ya know if it works
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
I know there is freeware and cables out there, but I went and ordered a OBD-II scan/reset kit for 23.97 shipped (China) ....looks like people are happy. Looks like it'll work with all 1996+ as it should. Nice tool to have around, get the codes before you go to dealer and be able to monitor parameters and reset CEL etc...can't tune with it but it could be a good tool...I'll post results and links once tested...USB
LinkNuc
Yes it indeed works! Comes with Scantools.net monitors a bucnh of real time parameters, and checks and resets codes.
http://cgi.ebay.com/ebaymotors...%3AIT
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
real time parameters?
LongBeachCoupe
2005 Lexus RX
Features:The program lets you perform the following operations:
Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).Clear trouble codes and turn off the MIL ("Check Engine" light)
Display current sensor data, including:• Engine RPM• Calculated Load Value• Coolant Temperature• Fuel System Status• Vehicle Speed• Short Term Fuel Trim• Long Term Fuel Trim• Intake Manifold Pressure• Timing Advance• Intake Air Temperature• Air Flow Rate• Absolute Throttle Position• Oxygen sensor voltages/associated short term fuel trims• Fuel System status• Fuel Pressure• Many others... Upcoming Features:• Data graphing and logging• Freeze Frame data• Continuous and Non.
LinkNuc
Thanks for responding to your own question. But year theres like 8 different screens of parametrs. Its a nice tool to have and will work on pretty much any make and model 1996 and up.
LongBeachCoupe
2005 Lexus RX
Make sure you bring that (and yourself) to carlisle this year!
LinkNuc
I really have no reason not to jump on the turnpike and come out huh? I used to live in Hershey (worked at TMI), hell I've been to 2 'vette cons. Throw me a beer, I'll reset your CEL, nice!
Hope you guys checked out the AACA museum while you were out there!
