Cheap Bottom Mount Replacement Manifold?
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
http://cgi.ebay.com/ebaymotors...ories
What do you guys think? Reinforce the runners a little more and should make a decent stock replacement.
flatrate
Car: S14 kouki
whats wrong with a stock one... that manifold has a horrible design and is no better than the stock one
"individual pipe for each exhuast port"
Cjmartz2k
Car: Hunting for a '89 GTR now
Just to clarify, that's a side mount a la stock, not a bottom mount. Bottom mount would be something like an HKS cast mani.
Flatrate, what about that manifold looks like a bad design to you? The design is fine, it's just a piece of s*** OBX manifold and it's going to crack.
OP-google "Stec rb manifolds" and you'll find the same design but it will NEVER crack. I'd stake my "internet cred" on that for what it's worth.
maryjane
had one of thoes manifolds on my 20, worked good, never cracked, removed because i switched to a 26
DrifterProdigy85
Yeah i know OBX sucks but im not gonna just bolt it on. What i was thinking is welding braces to each runner and to the flange all the way across. This should hold everything tight preventing a crack. Ill check out the other company though.
DrifterProdigy85
http://stec-motorsports.com/en...m=002
This would be better. 321 Stainless and 3mm thick piping. Ill spend the extra for this one. Itll save the hassles of welding extra crap on. lol. Judging by the design of the manifold, would you think you can fit a 30R on there without any clearance issues?
Cjmartz2k
It's the exact same placement as stock, that's all I can tell you about fitment. Remember, I've never owned an S-chassis RB swapped car, only a Skyline. If a GT30r fits on the stock mani, I would imagine it would be the same on this one too. BTW, ask Stec for the picture of that exact manifold glowing bright red and not cracking LOL.
Cjmartz2k
Nevermind, found it.........
colbol89
Car: 1995 240sx with SR20DET swap
JESUS, how f***ing hot did that thing have to get? How on earth would you even do that to your manifold?
flatrate
Car: S14 kouki
Cjmartz2k wrote:Just to clarify, that's a side mount a la stock, not a bottom mount. Bottom mount would be something like an HKS cast mani.
well for starters it has 1 pipe going to the flange with all the others dumping into it... far from efficent... it has NO merge what so ever either look at runners 1 and 2 its y'd to together... that manifold is pointless and unreliable
