When you pull whole axles out, transmission fluid will spill too. Its normal. Just add some.JMed wrote:ImStricken06, so me and my buddies did both axles and sway bar links yesterday on my Rogue. But now I see I have a pool of transmission oil by my car. Does that mean that something might be loose?
same here lolJMed wrote:I'm the kinda person that if I replaced one, I had to do the other one just in case.
YUP! thats the same problem i had. i ended up leaving the stuck part, and rebuilding it with a new outer shaftThe passenger side gave us some problems, it came out in two pieces. And the part closer to the transmission was stuck to the bracket that holds it, so we had to also removed the bracket and use penetrating oil, a torch, and hammer it out without damaging the bracket.
thats how my job was supposed to go. but my axle was seized into the hub lol. after torching it, burning the hub, and realizing i might as well replace:dave08902 wrote:My boot also ripped in the exact same spot as ImStricken06, I think that this is a design problem with Nissan. I felt inside the boot and I didn't feel any sand or dirt so I opted to replace the boot. Got new boot for 15 dollars and following the FSM it said to remove the outer CV Joint from shaft then remove inner boot. My CV shaft was also frozen in the hub and I used a three jaw puller and it came out. I disconnected the control arm from the frame so I wouldn't mess with the camber on the strut. Then I realized that I could replace the boots much easier. All I did was cut the straps on the inner boot and slid it open, then I removed retaining clip # 39735 and I was able to separate it from the intermediate shaft. Now I had the half shaft on the work bench. I then removed the c clip # 39734 and removed the propeller bearing using a soft mallet. Be careful as the three bearings can come off. With the propeller bearing removed now you can slide off the ripped boot off the shaft and install the new one. If the outer boot has ripped you can remove inner boot and then side off outer boot without even removing CV joint from hub. What is good about this method is you don't pull anything out of the transmission and is quick and easy. The entire job took me 45 minutes and 15 dollars for a replacement boot.
good work! usually heat works well on stuck nutsmpattdu wrote:Finally have a chance to post an update after finishing this job in November. The videos were tremendously helpful so a huge thanks to ImStricken06!
I was able to get away with just replacing the boot; replacement from NAPA for about $15. Luckily, no problem getting the axle out of the hub. Since I had everything taken apart I went ahead and replaced the tie rod ends and the sway bar links on both the passenger and then driver's side. Had to use heat on the tie rod end adjustment bolts, though. The biggest problem for me was actually the top sway bar link bolt. I got it broken loose but then it would just spin in the boot on the back side and there is not a lot a clearance to get another wrench back there to hold it in place. I ended up cutting it off. Had the same problem on the driver's side as well. All the work really screwed up the alignment but I was planning to buy new tires this fall anyway, so had those ordered and waiting at a shop nearby to have mounted and then have alignment done as soon as I finished the work on the driver's side.
looks like you're joining this badnwagon as well? lol i feel bad for you bro.darylzero wrote:For the people who replaced a front right cv half shaft what part/ part#/ model# did you use?
I want to make sure I get one that fits.
thanks
Yep noticed it on my last oil change. Wasn't horrible, but it ripped and there was some grease spread around.ImStricken06 wrote:looks like you're joining this badnwagon as well? lol i feel bad for you bro.darylzero wrote:For the people who replaced a front right cv half shaft what part/ part#/ model# did you use?
thanks
it all depends if you have the awd or fwd. many stores and shops cant tell the difference between the two. one is short, and one is longer. if memory serves me right, its the longer one for AWD.
