The service manual shows the low pressure port is near the firewall. The cap of that port also has the letter "L" on it. So I think it is the right port.Q451990 wrote:Should be the standard input... are you sure you have the low side port?
Heath
qship96 wrote:the ONLY way to check for the exact,correct amount of r134 is to evac,vac,recharge the correct amount back into the system-checking/correcting leaks during this process- just topping off creates a bigger problem.
