Charging Problem
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
esabatino
Car: Datsun 620 Pickup
The fuse labeled regulator, reverse, instruments (or something just like that) blew.I replaced it. It got real hot and blew again. I checked the voltage across my battery terminals, and it is not charging. Replaced the voltage regulator (with one from a u-pull-it) and got the same result.Checked my reverse lights and they're fine.If I put a fuse in, before it blows, the gas gauge and the temp gauge work. So do the reverse lights.It's Portland winter and I really need this truck to run. If anyone has an idea of what is wrong here, I could use the help ASAP.
PEZi
there's probably a short somewhere... its hard to say for sure where though
integradude19
Car: 1979 Datsun 620
1988 Supra Turbo
2004 350z Track
I'd check all your grounds and alternator connections. Check the connections at the relays under the hood too. Look for kinked wires, corrosion, loose connections, grease build up, etc.
esabatino
Been a long time since I've been on here, but it was simply a bad alternator.I replaced it and the truck is happy as can be.
plimits36
Car: 1977 Datsun 620 Pickup, 1969 Datsun 510 Race Car
if you've added any extra gadgets... i.e. lighting, stereo, etc. you may want to insure that your alternator is constantly putting 12 volts into your battery, if it's ever dipping below 12 volts. you will need to look into getting a bigger alternator put in. Also, you may want to check your grounds and make sure they are all good.
Return to “Datsun 620”
