BLKmomba1 wrote:yea the moderators should put up your thread in there it helped... and the dealer told me the same shyt that the slot charged the batt lol. wtf is it for otherwise? and it is super easy to change the key batt. i did both sets in like 60 seconds. thanks again riko
I agree, the moderators should put it in a thread, if for no other reason than to help those unfortunate soles who are incapable of reading and comprehending the Altima Ownwer's Manual.
Your question, "wtf is it for otherwise" is priceless. It proves my point about reading the manual, because if you would have taken the time to read it, you would not have asked that question. You would know the answer, as yes, it is in the manual.
Here is what the Owner's Manual has to say about the I-Key:
3-6 Pre-driving checks and adjustments
When the Intelligent Key battery is almost discharged, insert the Intelligent Key into the Intelligent Key port to start the engine. Replace the discharged battery with a new one as soon as possible. For more details, see .Push-button ignition switch in the Starting and driving section.
5-6 Starting and driving
WARNINGWhen the battery of the Intelligent Key runs down, insert the Intelligent Key into the Intelligent Key port until a click sounds. And then, push the ignition switch to start the engine.
5-7 Starting and driving
INTELLIGENT KEY BATTERY DISCHARGE
If the battery of the Intelligent Key is almost discharged, the guide light of the Intelligent Key port blinks and the indicator appears on the vehicle information display. See Vehicle information Display in the Instruments and controls section. In this case, inserting the Intelligent Key into the port allows you to start the engine. Make sure the Intelligent Key is placed in the correct direction: The front side faces upward and the key ring side faces backward as illustrated.
5-8 Starting and driving
NOTE:The Intelligent Key port does not charge the Intelligent Key battery. If you see the low battery indicator, replace the battery as soon as possible. See Intelligent Key battery replacement in the Maintenance and do-it-yourself section.
8-25 and 8-26 Maintenance and do-it-yourself
INTELLIGENT KEY BATTERYReplace the battery in the Intelligent Key as follows…….pictures included.
