Changing transmission fluid this weekend, question
lbrowne
I've read the archives, found out to use 75w90 for the transmission.
My 240 is a 5 speed.
My question is how much of it do I need, I plan removing the shifter and removing the 2 plugs in the transmission and lowering her down to level to drain it all out.
2 quarts? and half a quart of ATF? I've never done this before :)
Thanks
lbrowne
daniel240
Car: cars/motocross
i think mine was like 2 1/2 qt's but i might be wrong. i just asked them at auto zone and they pull it up on their comp. and tell ya.
240_Keyy
Car: '90 240 Fastback
yes, it is 2.5 quarts. I just changed mine about three weeks ago and it was the original fluid (with 200k miles on it) the oil looked like badly burned motor oil, it stank like a mofo and there was a golfball sized chunk of gear teeth on the magnet. Maybe that is why my transmission shifts funny.....
Still didn't smell as bad as the oil I got out of my open diff, fook, that stuff was NASTY!
red240ne
Car: mmm...donuts
FSM says it's 2.4 liters, or 5 1/8 pints.
lbrowne
perfect, thanks fellas!
scuba_sean
Car: snowboarding, sailing
ya, my chiltons says 5 1/8 pints or 2.42 litres. im dropping the transmission, (cause my 5th gear up and buggered off on me), and im gonna fill it up with royal purple MaxGear oil. i reccomend doing the same.
Silvia007
Car: 93 Nissan 240SX SE Fastback
I don't know about adding ATF into a manual... maybe if you want to clean it, pour some in and run it for a mile or so and drain it. But I don't think mixing atf with Gear oil would be a good idea.
Scott McLellan
Sorry this is off the subject kinda but when you pull the driveshaft out of the trans. it says to plug it so it doesn't leak. How bad does it leak when you do this? and also what do you plug it with, a rag or something?
lowpsi
Are you guys sure its 2.5 quarts..nissan here told me it was a little over 3.5 qt..Even autozone told me the same thing........Z:confused:
moses
5 pt = 2.5 qtI just changed mine last week on my 93. I had 5 quarts and used all of it between the diff and the transmission (but I had a couple spill problems). 3 quarts should be enough.
lowpsi
moses wrote:5 pt = 2.5 qtI just changed mine last week on my 93. I had 5 quarts and used all of it between the diff and the transmission (but I had a couple spill problems). 3 quarts should be enough.
3 quarts should be enough for the transmission and the diff. or just the trany???....Z
moses
Sorry, 3 should be enough for the transmission.
slw240sx
Car: 1990 Ca18det 240sx Hatch
ahh it will leak alot, espescialy if you tip it backwards !!! i learnd the hard way when pulling my motor,, we totaly forgot to empty the transmission out all of it poured out Jon
sheadee240
What brand of fluid has worked best for you guys?. [/QUOTE]
