Cloudedone »
https://forums.nicoclub.com/cloudedone-u3897.html
Mon Feb 03, 2003 2:28 am
The swap should be fairly straight forward, if you've never done a transmission swap before i would sujest you buy a hayne's/chilton manual for the car and follow the instructions in it. Otherwise, its fairly straight forward, remove drivelin, clutch slave, starter, stick, wires, support with jack, remove transmission support, then transmission to engine bolts, slide back carefully out of clutch disc and past the pressure plate, then lower... sometime it help to jack up the front of the engine, which tips the motor back to you can slide it out easyer...
