Changed injector #6 with plenum on...
Qdog
Car: 92 Q45
2 months after doing the complete plenum job (had all the injectors out & cleaned or replaced) I had an injector failure, #6, under the plenum. I removed all the plenum to runner bolts, removed the IAC, and lifted the plenum up enough to remove #6 and replace it ! Last time I had to press out the injectors in a vise (socket over the bottom). I used silicone assembly lube on the O rings during re-install. This allowed the injector to slide out with minimal force with the rail still in place. Put in my spare injector (with silicone), back on the road ! Doug in Cali, if you're reading, it wasn't one of yours that failed.
DAEDALUS
Car: 1990 Infiniti Q45
That's awesome Qdog! Thanks for the great info.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Golden. Im hoping no injector failures for me, we have good gas here so less chances of messing them up.
DougQ45
Car: Q45, porsche 928 S 5 speed
Qdog: Thank god it wasn't one of of the injectors I sold you as the guilt would make me crazy. I have a couple of spares left, but had to pull my plenum for second time in a year to replace 3!!!! out of spec injectors. Wouldn't wish a multiple plenum pull on anyone but the second pull was much easier. Good to see you figured out how to do the injector without complete removal. I thought is was possible with skinny arms, long fingers, and alot or pre-streching!
DAEDALUS
Hey Doug, on your 2nd plenum pull, were you able to reuse all your hoses?
DougQ45
hoses were all good because the dealer replaced them all for the former owner about 2 years ago--lucky I guess
