ch them to the Checking Ohms of Injectors..
b_vanfossen
Car: j30t
Do I take the posative and negative cables of the meter and touch the to the electrical post connections of the injector and take the reading
OR
take the posative cable of the meter and touch it to the pos. side of battery and then the neg side of meter to one post on the injector?
Thanks for your help!
Modified by b_vanfossen at 5:55 PM 6/17/2008
gr8scott72
Car: 1994 Infiniti J30t
b_vanfossen wrote:Do I take the posative and negative cables of the meter and touch the to the electrical post connections of the injector and take the reading
OR
Just across the injector.
b_vanfossen
Car: j30t
I checked it and there was nothing to read across the injector. It was 0. can it read 0?
Thanks for your reply.
coolyun_98
Car: 1993 J30 11,7000kM
It is the resistance not the voltage that you are measuring.
b_vanfossen
Car: j30t
I don't know about this- but the meter weas put in the lowest ohms setting (20 k I think) and noting registered.
doesn't matter the injector was bad and now it is fixed. I was just hoping to learn how to read it for next time.
thanks
yodawill2000
Car: 94 Infiniti J30
It should read about 14 ohms resistance if its good.
gr8scott72
b_vanfossen wrote:I don't know about this- but the meter weas put in the lowest ohms setting (20 k I think) and noting registered.
thanks
Is your meter working?
Q45tech
Go to radio shack or supplier and purchase a 10 or 12 ohm 1/4 watt resistor to use as a reference to check VOM calibration.
Low ohms are very sensitive to VOM battery condition.
Most Nissan injectors read 11.9-12.0 +- 0.3 with an accurate VOM.
