voltron »
https://forums.nicoclub.com/voltron-u4601.html
Mon Jan 27, 2003 8:35 am
Here are my opinions on this subject; Aluminum resists corosion better and weighs less. It weighs less regardless of the metals tensile strenght. So I would prefer that the engine in my car is made of aluminum. The rest of it? Engine tuning is a factor way before the metal used to build the motor out of. Say you have two race cars one with an iron block and one with an aluminum block, both motors are runnning 20psi on c16. Lets say then that detonation occurs at the same time in each motor, what breaks? Probablly the ring lands if you are lucky. Maybe you melt a pistion. Whatever. Maybe the question should be what metal will fare better in the instance of catsitrophic failure? I guess then that the iron block has a better chance of being re-used.
