carbon canister
ignigknot
Car: 1991 240sx
I've searched and i stil don't know which ones of those 4 hoses coming out from under the manifold connect to the carbon canister. Also, a line that goes behind the engine and comes out above the turbo( its a metal hosing line).
slownslurious
the long one, I think its in the middle, terminating in a rubber hose, thats the one that goes to the carbon canister. that vaccuum line above the turbo I have no idea, I had mine capped off, then I hooked it up to vaccuum, and now its crimped closed, and none of it seemed to make a difference... does anyone know what that is? I don't see it on the FSM diagram.
fallen180sx
Car: 90 Sil80
my buddy told me to trash the canister.. said it was emissions
float_6969
Carbon canister is for emmisions. If you're concerned about hooking it up, look in a 240sx FSM. I'm fairly sure that it's in there. I'm at work, so I can't look right now.
ignigknot
Car: 1991 240sx
So i can safely plug those 4 hoses then?
fallen180sx
Car: 90 Sil80
its what i did.. and no problems here.. and everytime you look at a ca in a usdm car.. you never see that big black thing anyways..
rico05
Car: 1992 RMS13 w/ CA18DET
Plug em and chuck the thing. IIRC I only have 3-4 vac lines on my head connected up.
em55ery
Car: 91 nissan 240sx
id like to know the same thing.. i also heard though that you get the signal for a boost controller and or boost gauge from one of them.. if u plug them where acn u get those vaccum sources from
em55ery
cmon guys any help
rico05
My vac source for wastegate and BOV comes from right behind the throttle body on the intake manifold. The sources for the FPR and butterfly actuator comes off the back of the mani. Really, I just have 2 vac sources IIRC, just used Ts to send to different actuators.
float_6969
rico05 wrote:My vac source for wastegate and BOV comes from right behind the throttle body on the intake manifold. The sources for the FPR and butterfly actuator comes off the back of the mani. Really, I just have 2 vac sources IIRC, just used Ts to send to different actuators.
The manifold actually only has 2 spots for a Vac. reference. One on the passenger side of the intake mine, lower on the plenum, right behind the TB. It's a larger diameter. The other is on the back side of the plenum, and is a smaller diameter. I'm using the one at the back of the mani for my butterflys and the FPR. The one at the front, near the TB, is currently feeding my MAP sensor (I have an SDS Standalone), but will also feed my BOV. You could also use it for the wastegate.
Coldspawn
Do not plug the metal line going back to the gas tank. It vents the gas vapors. If you plug it, it will pressurize the gas tank.
float_6969
This is true. What I did with mine was bend the line so that it just pointed down underneath the car, away from anything hot.
em55ery
so can someone give me a for sure answer about those 4 hoses lol
knightrider
Car: black 90 240 coupe
download the fsm, it will show you all you need to know. also your wastegate signal should come from before the TB, not from the manifold, the bov should be tapped into the manifold.
biosehnsucht
YOU ARE VENTING THE FUEL TANK TO ATMOSPHERE !??!!?
slownslurious
yeah and I have been for a year with no problems aside from some gas fumes.
em55ery
uhh yea lol.. u may wanna put a breather filter on that.. lol.. but anyways guys.. can someone im me.. em55ery or give me a straight answer on here about those 4 bunched vaccum hoses etc... oh and i have a fsm.. if u wanan give me the page or section i can find that in..by all means ill go there but i cannot find it
slownslurious
I don't know for sure which 4 hoses you mean, but I would like to know about the one that comes around the back of the engine and bolts to the turbo outlet thing... wtf is it...
biosehnsucht
for the 4 tubes look at my huge post in the FAQ sticky
I need to rework it a bunch as its horribly written..
edit: I wasn't paying attention and when you said 4 assumed you meant the 4 pipes at the intake mani, which do cause alot of confusion. If you meant the ones at the charcoal canister (of which I only see 3 in the diagrams..) then I'm not sure off hand what goes where and I'm too lazy right now to look and tell you but you can see where everything goes in the following FAST sections:223 - VACUUM PIPING173 - FUEL PIPING
that would seem to indicate two to the intake mani and two to the tank.
Modified by biosehnsucht at 12:16 AM 8/26/2005
Pumaking
Bio I have a question now in the diagram for the vacuum piping it shows Automatic and Manual what would you go by if my CA was a Automatic converted to Manual?
float_6969
Manual
biosehnsucht
yeah. I only include that for completeness. in this case the only material difference is the solenoid to reaise the FPR for hot starts or such sillyness.
