lancekilgore »
https://forums.nicoclub.com/lancekilgore-u110504.html
Wed Dec 31, 1969 5:00 pm
Ok got back home from othe job and messed with it some more. I can't get it to start 10 Degrees or lower so I readjusted the float, set the timming and then the carb.
for your question really by adjusting the rpm screw you just bring the idle up does not really help the proper adk=j of the carb. Keeps it running though. unless your idle is under 600 to 700 which is where it should be by the book. My float was way off and was cauing the problem. guess I will see if it starts in the moring or not.
Ok so I have a question for anyone who messes with carbs why does the datsun carb when you give it gas revs go way up and take time to go back to idle?
Most carbs go right back to idle. does anybody else have this problem and what is the fix for it/
Thanks Lance
