Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Tue Aug 19, 2008 12:54 pm
I would agree that the problem is either your ignition switch or ignition control relay. Swap them out with a used one and see what happens. Ignition switch costs less than $50. Faulty ignition switch will continue to send current to the solenoid---you will hear it move, but it won't turn the starter. As for the relay, you will see it in the box in the engine bay marked "ignition". Remove it and tap it or dip its top in hot water to see if it helps.
