DeviousNismo_240 »
https://forums.nicoclub.com/deviousnismo-240-u3753.html
Wed Jan 22, 2003 12:37 pm
First off, Its the blue relay, w/ two connectors, and it is fastened to the inner fender, via a bracket. You, can test it, but, let me tell you, I would just replace it. Its cheap, and even if that isnt the problem, which im sure it is, you have a new one, or a spare to keep in the glove box. Im a Nissan tech, and ive seen more parts customers, and inexperienced techs chase there tail, for a no crank situation, only to finally ask the other guys, or myself, and find out that it is just the relay. Second, you can jump the wire for the clutch switch, but may I ask, why do you want to do this? doing this means that the car will start in gear, and take off. mho, I would just plug it back in and leave it alone.
Good luck,Josh
