car will not turn over 87 300zx turbo
xdtrl
Car: 1987 Nissan 300zx Turbo
Ok so my car is stuck at a parking lot for now. my car started fine today and i drove it about an hour away and stopped to get gas....when i returned i went to turn the key and i got nothing, all my lights come on on my gauges oil,seatbelt etc but im not getting anything. it wont turnover at all...it wont even make a clicking noise. at first i thought it was the battery but the battery and battery terminals are fine. i think the alternator is fine and the only thing i could come up with is that the starter went to crap instantaniously....weird i know. but even if the starter did go out wouldnt it at least grind? could it be my ignition? Any help is appreciated i have 3 days to get my ride moved so they dont tow it.
nichols1992
You're going to have to check for voltage at the starter. Check the battery cable at the starter, Then have someone attempt to crank the engine and check for voltage at the ignition wire at the starter. If you don't have voltage at the ignition wire while attempting to crank the engine then you may have a problem with the ignition switch or your theft warning system.
xdtrl
I swapped out the battery and i still got the same thing......When i turn the i get a click and my gauge cluster turns on but it still wont turn over. Im going to have to get it towed home and with that said Im out of work for 3 weeks so its hittin hard.
MidnightLamp
Car: 1990 S13 Nissan 240sx
Ok, we need some background on this to troubleshoot.
Here's some things to try:-Check the fuse for the starter/starter relay.-Check the starter solenoid. A little impact helps it if it's stuck in place, but it's only a short term fix.-Push start it if it's a manual car.-Check the ignition switch to see if part of it is not functional.
Nish
