MrFeesLaw »
https://forums.nicoclub.com/mrfeeslaw-u256297.html
Wed Feb 10, 2016 12:15 pm
I would check the hydraulic system. Feel the clutch pedal. Does it feel like it is "soft", or "spongy" when you push it? or certain problems may even cause it to feel "stiff", which would be very noticeable.
Have someone pump and hold the clutch pedal, as if you were doing a clutch system bleed procedure. Then watch the master cylinder for a minute or so. Then follow the line down to the slave, checking the master, slave, and line for any signs of leaking.
If there don't seem to be any leaks externally, I would move on to testing the clutch and other hard components before checking for internal leaks. If you have a master cylinder leak your pedal will likely not have much pressure at all, and there should be a pretty obvious external leak. The slave, however, can have an internal pressure leak, which is a little harder to diagnose. Usually with the car off you should be able to shift from neutral into and out of every gear in the transmission with little effort. If some gears are stiff, or won't go at all, you may have a problem with your slave.
Another test that works for some cars is to put the car in gear with the engine off, and then, without using the clutch, turn the car over for a second or so. If the car moves forward then you have proved that your clutch is at least making some sort of physical connection with the flywheel. If you crank the engine, and it spins over, or even starts, without moving the car, then the clutch is not making any connection with the flywheel, and is obviously not going to work anymore.
^Not entirely sure how the car would act if the clutch was just slipping, and not completely gone... Maybe it would jerk on some rotations and not others?
Does anyone know of any other tests that may help narrow down the problem without disassembling anything just yet?
