fuse huh? Ill check that out, but tomorrow Im going to try and remove the intake manifold to try and get to the coils under them...i think mine in Cylinder 2's gone so Im only running 3 good cylinders. I believe that may be the issue. Ran a diagnostic on it and it came back "random misfire" then tested it again, after driving it for a bit, and it read "misfire cylinder 2" so idk whats going on...NissanXEPIlot wrote:Sounds like a Mazda truck I had. I rode it for months with it stalling at traffic lights and stop signs. Rebuilding the carb, and swapping out the ECM didnt work. Months later I was replacing a fuse for the radio and notice a empty spot marked Engine. I popped a new fuse in and that solved the Idle issue. Turned out my brother blew a fuse to the radio and used what he thought was a spare fuise.
Since mentioning the exhaust though It could be the catalytic. (assuming you still have one.)
I believe my car only had a 36000 mile warranty. Ill ask. But IM a little PO!! Right now.SpecDRacing wrote:Your car has a 50,000 mile powertrain warranty that should still be good. Take it to a dealer.
