whiteflash »
https://forums.nicoclub.com/whiteflash-u81518.html
Sun Nov 25, 2007 12:29 pm
I agree with just about all gaskets and rubber will have to be changed, but don't forget, before you move it under it's own power you wanna check those individual wheel cylinders and be sure your brake seals are ok,top up fluid and and press brake pedal before you look you should be able to see leaks easily. change the pcv valve it's likely stuck, the other posts covered most of it but you might also consider an oil filter magnet, after sitting the oil has settled and condensation inside has caused minor rust spots and thats gonna leave alot of floating oxide soooo magnet look up FilterMag I know there are others but I can remember that one. your alternator and water pump may burn out soon too (because of rusted bearings, and before cranking might buy a radiator flush kit, it's like $8 or less, that stuff is gonna be rusty too. I have a D500 I've been rebuilding for a couple of months that was abused and it needed a new rotor and cap, whether you have an auto or man. you still need to check that clutch cable, and flush the transmission fluid completely, if your cv boots are cracked enough the grease has dried up too IMPORTANT if you want to keep those (that is assuming they were working when parked) repack those with heavy gear grease and buy new boots for it (usualy about $14-20) good luck I couldn't live without mine either. Anyway thats my 20cents
