YES!!!! EXACTLY!! Its like the engine doesnt want to get up on its own, so I have to shift at higher rpms.
I was looking online and z1 explains the whole problem with the detonation/knock sensor.
http://www.z1motorsports.com/product_in ... ts_id=1727
The reason why its sounds smooth at higher rpms, like z1 says, is because i cannot distinguish the noises coming from the engine.
So I myself, and others who have the same problem as me with the det/knock sensor, have 3 options. I read that this job could cost around couple thousand at a shop, f that. This would prob be either taking out motor, or plenum, and replacing the sensor itself and the wire (most likely the wire is at fault not the sensor itself). or by taking the transmission out and doing it from behind.
the second way, which is the cheapest, but not the safest, is to completely cancel out the sensor, tho incase there is knock, your ecu wont know it, and will continue to run normal with the knock, that would mess up the motor even more. and that fix is right here
http://www.z1motorsports.com/product_in ... ts_id=5580
Its just a plug and it gives back the same resistance as the sensor does under normal conditions... not safe at all..
and the 3rd and final one, the safe yet inexpensive one, is like what solaire said, to do the relocation. and this one guy explained it best, there are 3 different places to do it too. heres the link to it, he gives part numbers and everything.
http://www.twinturbo.net/nissan/300zx/f ... ation.html
So I will be doing this and hopefully it will fix the problem.
since they said that its most likely the wire going from the sensor to the sub harness, I will be getting this little guy here
http://www.z1motorsports.com/product_in ... ts_id=6565
and then i will get the knock sensor prob from CZP or even Z1, and then the bolts, and washers and nut from the hardware store down the street or where ever.
Hope these links help and will help those out there that has the same problem as me with the dreaded 34 code. I will post when its complete and give you guys the results of what happened.
Peace!
