So I took it to my local Autozone and the battery and Alternator passed the tests. I also managed to get it into limp mode (I found that when i first start the car and rev it past 5k usually it triggers when the RPMs drop back down) and we scanned the OBD2 while it was in limp mode AND THE SCANNER SHOWED NOTHING. I don't know what else it could be!centralcoaster33 wrote:Hey Salvy, I think your alternator may be going bad. At least, that's what your lights mean. It's new, so perhaps it's a defective unit or installed incorrectly. If I did it, I'd double check all the wire connections and grounds related to those new parts. Can you get to a local parts store anytime soon? Many have free battery and alternator testing. I think you need that test. Let us know how you decide to proceed. Thanks.
Here is the car limping on the freeway: https://youtu.be/FLLOcHjRnnYcentralcoaster33 wrote:Okay, did you do or have someone do some work recently? In addition to the above mentioned parts? I wonder if a sensor is unplugged or something, but I think you'd get a code from the scanner. It's time to refer to the FSM. What 'limp mode' do you experience? Fuel cut? Max RPM maybe?
Or you mean like no power, it's not running on all cylinders type stuff? Here's a link to the chapters to your FSM. FWD is the table of contents chapter. I recommend flipping through the EC chapter. There's a lot in there, so get a cup of coffee first.
http://www.nicoclub.com/FSM/Altima/2008/
I actually thought of that too. Last 3 days I've been driving with the power for the amp disconnected from my battery and I've driven with the stereo turned off and it still limps. I caved and took it to Nissan to be checked (even though another dealership originally diagnosed it as a bad alternator and battery terminal.) I will update when they call with what they find.centralcoaster33 wrote:I'll have to wait for a break to watch the video (I'm workin' today). For the sake of diagnoses. Temporarily pull the big fuse out of your power to stereo stuff or just disconnect it from your battery. Also, remove the ground to chassis wires you may have added for amps and stuff. Also, turn off your stereo head unit completely. Now test drive and see if you still get limp mode.
