carmo »
https://forums.nicoclub.com/carmo-u91933.html
Sun Sep 28, 2008 1:29 pm
I wonder if it's distributor related. I'm pretty sure that is one of the vehicles that has a leaky distributor. What will happen is oil will leak inside the distributor from a bad shaft seal and coat the signal ring. When this happens, the cam sensor does not read properly and the motor runs like poopies or won't run at all. I have yet to find a rebuild kit, so if this is the issue, your gonna need a new distributor. Or maybe the guy mixed up the plug wire when he reinstalled them. That would be fairly hard to do. Maybe after fixing the two main oil leaks the pressure inside the engine is just ever so slightly higher. Because it's sealed tighter now. And suppose this caused a weak distributor seal to finally begin to leak. Just a theory. May not be true, but it sounds good. Good luck and welcome to Nico. Let us know what happens.
