cant find oil leak, HELP!! and not boosting well. knock sensor help, PROBLEMS!!
KEMP
Car: 1990 240sx CA18DET
im leaking oil from the intake side of the motor, i have no idea if its coming from the valve cover relief, or what, its leaking decently, but not pouring.
i just did a head gasket job as well, and i know that the hard oil line going to the oil filter housing goes to the valve cover relief, but i do not know why it would leak so bad from that, can anyone shed some light on that?, i also do not currently have the knock sensor out because i broke it and im poor so i cant get a new one yet, would oil come out of that hole?
also what could the knock sensor do to my performance. i am running and external wastegate with hks evc 6 boost controller, its not boosting past wastegate pressure, any ideas?
thanks.
Anu
Car: Nissan 200SX s13
The hole for the knocksensor is not connected to the oilcircuit of the car as far as i know, so I dont think the leaking is comming from there, did you replace the rockercover ( I think its the correct english term :P)gaskets and tighten the screws? I've had the cover leaking oil because the screws got loose.Just clean the blok, and check where the oil is comming from I guess.Also if your car is tuned correctly, the knocksensor should not have any influence on performance. Only when the sensor is detection knock, it will change the timing ( I thought it was the timing, not 100% sure though).
slideordie85
Car: 240sx
I know I had a leak in the intake cover coming from the back and it had caused oil to seep and a wierd idle. Eventually I just pulled the hose and replaced it.
