alright2020 wrote:Is it possible to replace the piston rings, rods and main bearings from the bottom end with only pulling the oil pan?
i ask because i had an oil line pop off over the weekend and didnt realize it immediatly and i think i may have slightly starved the motor of oil.... i am pulling it on friday to find and fix the oil leaks completely. but i wanna say i hear teh slightest start of a rod beginnning to knock. id rather not do all teh work pullign it out and all and putting it back in to start knockin. i havent driven it since and since bearings and rings are relatively cheap i figured if i can replace them i will
should i jsut replace with oem sized rings? the motor has ~30k miles.... or will i need to do it the proper way and pull all the rods out and mic them out?
Nope. If the heads are still on, how will you pull the piston out once the rod cap is off? Or the crankshaft?
Sorry to hear about your troubles though, really sucks man.
