can i use 97 ecu on 95 engine?
starfireS14
well can i?
APEXi240
Car: 08 Nissan Versa S hatch
If I remember correctly the 95 is OBD1 and the 97 is OBD2. They will not work together correctly.
starfireS14
oh ok can i put a 95 ecu and 95 ka in my 97 then?
APEXi240
Yeah, you can do that. You can MAKE the 97 ECU work in the 95, but its not worth the trouble.
On a side note, does anyone know of any companies that make an OBDII to OBDI jumper? Like on Hondas?
starfireS14
ok well my car is a 97 and im putting in a 95 engine can i just use a 95 ecu?
Aries
Car: LT1 240SS
yes,do you need one?
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
starfireS14 wrote:oh ok can i put a 95 ecu and 95 ka in my 97 then?
95 and 97 240SX are both OBDII. The ECU swap *should* work.
Grandpa
You are wrong, the '95 ECU is OBDI.
Aries
Car: LT1 240SS
EZcheese15 wrote:95 and 97 240SX are both OBDII. The ECU swap *should* work.
Torry, until November of 1995 the ECU was still ODBI and used a grounded puls signal instead of the ODBII's inter-relay pulse signal.
But since all of the November and later 1995 240's were sold in Canada, this one is most likely ODBI.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Aries wrote:Torry, until November of 1995 the ECU was still ODBI and used a grounded puls signal instead of the ODBII's inter-relay pulse signal.
You sound like you know more about it than I do, you have some documentation backing that up? I'm just curious, I'd be interested in seeing that.
MadSideways
Car: Cars, women, drifting...the usual...heh
My 95 240sx has got an o2 sensor after the cat...I thought that was something only common with obd-II...
Lepchitz1
Car: Cars, and LESBIANS!!!
MadSideways wrote:My 95 240sx has got an o2 sensor after the cat...I thought that was something only common with obd-II...
Nope! What part of atl you from?
starfireS14
Aries wrote:yes,do you need one?
well yes i do email me [email protected]
Aries
Car: LT1 240SS
you have mail.
SR180SX
If I am right, 95 and 96 are difference and 97-98 are the same, 3 different ECU in 4 years, but double check I might be wrong.
Aries
Car: LT1 240SS
you are correct.
yellow_jacket
Car: 95 240sx
Personally, I would just swap intake and exhaust manifolds. That way you wouldn't have to buy anything else.
starfireS14
yellow_jacket wrote:Personally, I would just swap intake and exhaust manifolds. That way you wouldn't have to buy anything else.
yea i planned on doing that just wondering about harness and ecu im buying a 95 ecu to send out to JWT as for harness I'm not sure
