Can a z31 Alternator be swapped out for a z32 one?
A home for 1983–1989 300ZX owners!
ZedZillaZ32
Car: 300zx TT, 280zx NA
As the title says, my alternator in the z31 happily brings all my good batteries from 12v to 8v till finally the car dies.
I just put in a bit of sound gear last night (post dodgy alternator) and I have a busted z32 TT one I could get rebuilt to slide in and help with the sound system and keep the car alive since Im sure it would provide more amps then the z31's.
It looks doable, just need to change the pully from ribbed to v belt which I can grab off the dud one.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
not sure if the mounting ears or plugs are the same but both are internally reguated alternators and work the same way, so in theory it could be made to work
ZedZillaZ32
I think I found a problem here
Does this just earth onto the housing? can it just be crimped back under one of the two smaller nuts around that big one?
evildky
06 Nissan 350Z GT
thts just a noise suppressor, you can remove ti and will have no ill effecte, aside fome maybe a ground loop whine through your stereo
ZedZillaZ32
Y
evildky wrote:thts just a noise suppressor, you can remove ti and will have no ill effecte, aside fome maybe a ground loop whine through your stereo
Yeah found that out too not that long ago, dam it no I gotta go back under the car
ZedZillaZ32
do youhappen to know the amps of the Z31 one
ZedZillaZ32
The following photos show my two alternators left is Z31 and rightis Z32
Besides the housing design differences front side dimensions the same
rear side view shows the harness goes in slightly different places but it all connected up
All the brackets and pulleys line up
So my conclusion based on an opinion from a member of another forum that the two cant be swapped because "There is a square plug, a small earth that is screwed into the housing, a positive that is bolted down using a nut" is that a previous owner has already converted my car to z32 because I give you the harness as used on my Z31I can see that the plug/crimps were put there post nissan factory
What do you think?
Return to “300ZX (Z31) Forum”
