Cams
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
Ok what are good cams to use for a Ka-t i want power all the way to 6k and be good with turbo saw somewher some guy had PDM stage II cams on his Ka-t would this be a good setup or is ther better cams out ther for that price
SingleCamSam
Stock cams should give you good power up to 5500 or so. If you just want modest gains you could using two exhaust cams from an S13. They have 248/248 durations as opposed to 232/232 stock.
Charlie240sxt
I know that and i want wore than the stock s13 lift
WDRacing
Wouldn't get to crazy with lift, unless your also doing the valve train. I'll have some kicka$$ cams out in Febuary. I just need to install them to get some dyno results.
WD
Charlie240sxt
But do you think the Pdm stage II cams would be good WD i dont want to go crazy but more then the S13 cams
WDRacing
What is the duration of the stgII cams??
Charlie240sxt
Intake 219 duration, .379 lift, Exhaust 221 duration, .384 lift.
WDRacing
I thought the stock duration was 240??? You don't want to go smaller.
WD
SingleCamSam
Seems wierd to me too. Aren't there different ways of measuring duration?
Projex240
Car: Dogs , My RIDE
I believe that is why you have to use the newer shims to bring them back to spec and they will have a bigger effect on performance.Other than that....I agree with WD. All turbo cars benefit more from duration than they do lift.
rco8786
Ya, but w/ turbo cars you can't have any overlap. well, i guess you can but it wouldn't be very good.
s13sr20chris
you can have some overlap just not much. that is unless you are an engineer. the pdm cams are prob measured at .050 lift. i am not sure about the stockers. now that i think about it, those are still really low numbers. a good question for pdm.
MikeMurphy
Car: Guess
Projex240 wrote:Other than that....I agree with WD. All turbo cars benefit more from duration than they do lift.
I would have to politely dissagree. I thought it was well known that good turbo cams are relatively short duration with a high lift.
WDRacing
Stock RB20 cams are 240, really good drag racing cams are 272, ...alot of it has to do with RPM range and boost range also. If you run low boost then you don't need any cams. If you have a bit of lag and run higher boost, then a cam with top end performance is what you want. You can have longer duration cams without overlap, but you need adjustable cam pulleys to tune them.
By the way, I like your car Mike. Nice clean lines.
WD
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
s13sr20chris wrote:the pdm cams are prob measured at .050 lift. i am not sure about the stockers...
You got it backwards...
Stock is measured at .500 lift...PDMis measured at...well, read bove here where "Charlie240sxt" states:
"Intake 219 duration, .379 lift, Exhaust 221 duration, .384 lift" for th PDM cams...
You can't compare the specs, unless we can get numbers for the PDM cams at .500 lift...
I'd bet they are something like 256 duration, like the JWT set...only not as good.
Later - Brian
s13sr20chris
.500 lift? no way bro. i think someone printed some wrong specs.
WDRacing
Thats not the lift, thats where the measurement is taken.
WD
Charlie240sxt
Sorry when out of town so does any body have cams that are street able and can be use with out tuning and will poweer the ka-t to about 6000-6300 with good power
s13sr20chris
:: orion :: wrote:You got it backwards...
Later - Brian
yeah, if you measured it at .500 lift, it would be negative or something. this is a mess. there are some wrong numbers floating around.
