mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Fri Aug 13, 2021 10:30 pm
Interesting... If you're referring to the strut mount bolts at the knuckle, then I could see using the top hole for this to rotate the knuckle in or out to affect the camber. I would definitely want a shop laser alignment done at the same time that camber adjustment bolt is installed. I haven't heard of this being done before now. Nissan's/Infiniti's design intent and structural integrity of that nonadjustable, but made adjustable, strut mount position at the knuckle would be compromised but I have no idea if it would be a serious issue. I would have the alignment checked first, without the modification, to see if the camber measurement is thrown out of spec after the lift. The more I think about this, the more I am inclined to say don't do it.
