CAM Question??
02maxSE
Car: 2002 MaximaSE
Does any one know of a company making cams for an 02 3.5? I read that JWT makes them for a 3.5 i called and they wont be back till 4 jan. if anyone hears anything please let me know. thanks.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
here's the parts off of http://www.jimwolftechnology.com :
"PART NUMBER: A3503-N00C2
DESCRIPTION:C-2 JWT CAMSHAFT SET VQ35DE 261 DEG. / .456" (11.58MM) LIFT RACE CAM SET FOR NA AND BOOSTED ENGINES
THE JWT C2 PROFILE IS CONSIDERED A RACE GRIND AS ARE ALL OF OUR "C" SERIES CAMS AND IS DESIGNED TO OPERATE WITH JWT SPRINGS. THIS IS A DESIGN WE ARE EXTREMELY PROUD OF, AS IT IS A VERY TIGHT DURATION FOR THE LIFT AND REQUIRED AN EXTREMELY PRECISE PROFILE TO SAFELY MAKE THIS LIFT AND STILL STAY ON THE STOCK FOLLOWER DIAMETER. THE TIGHT DURATION AND HIGH LIFT ALLOW THE C2 TO PERFORM WELL AT MID TO HIGH RPM IN NATURALLY ASPERATED ENGINES AND YET THE C2 HAS SEEN OVER 800HP IN BOOSTED FORM!
PRICE: $1,198.00
http://www.jimwolftechnology.c...S.jpg
PART NUMBER: A3503-N00S1
DESCRIPTION:S1 CAM SET FOR VQ35DE**. JWT S1 BILLET CAMS ADD 15+HP WHILE MAINTAINING EXCELLENT DRIVABILITY AND GOOD IDLE QUALITY.
260 DEG DUR. / .428"(10.9MM) LIFT, INT. ADVANCED 2 DEGREES. ** NOTE: THIS CAM UPGRADE MAY REQUIRE THE IDLE RPM BE SET TO 850 RPM TO PREVENT POSSIBLE STALLING AT IDLE. 2004+ LEV II VEHICLES DO NOT ALLOW FOR IDLE ADJUSTMENT AND SHOULD NOT USE THESE CAMS WITHOUT SEEING OUR TECH SECTION ON IDLE STABILITY MODS. WILL NOT WORK ON 2005+ REV-UP ENGINE WITH EXH. CAM CONTROL.
PRICE: $1,198.00
http://www.jimwolftechnology.c...O.jpg "
02maxSE
Car: 2002 MaximaSE
Hey thanks alot for the info. i plan on putting the cams, headers, and if they come out with a supercharger on it when i get back later next year off my deployment over seas. i'll have more then enough money then. pics will come. thanks again.
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
no problem. while you're there get me a MEVI! also, i guess the SC kit for the 350 won't work on the max b/c of the FWD/RWD diff? oh well, good luck and be careful over there.
02maxSE
Car: 2002 MaximaSE
No problem. Just one small question, what's MEVI? I might be in south america it will be the first time there so i don't know what they have. but i'll look.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
MEVI = middle east variable intake. it refers to the difference in the maximas intake runners. here in n.america we just have plain, standard, regular runners. however, maximas in the middle east have a different setup with their intake runners. they come from the factory that way, and from my limited understanding they work similarly to hondas vtech engines. hince, the "variable intake."
here are some links w/good info if your interested...1) http://www.courtesyparts.com/M...IFOLD2) http://forums.maxima.org/showthread.php?t=2170013) http://www.nissanperformancema...sarah/4) zerothread/213099
hope this helps answer your questions!!
