float_6969 wrote:I think you can actually make an 86mm piston fit in a CA. IIRC, NISMO had one for the CA. It was a super high compression pistion, and was designed for a N/A application. I think it almost got it up to a 2.0L.
Not something you would want to do for your daily driver though...
i remember seeing this too..
and from looking at my block i am very very tempted to go with 85mm 9:1 CR CP pistons and see what happens, there looks to 'me' to be enough room to take out a extra 1mm on each cylinder with enough room for structural regidity etc..
i know from the wiz david wizard, that increasing cylinder bore increases compression alone so i dont know if increasing it 2mm will increase the compression too much along with 9:1 pistons.. i know there is a formula for calculating compression increase due to bore increase...
would be an interesting motor though, you 'may' loose some of the rev happyness, but with the increased compression and bore/displacement you may not need to swing 8500rpm...
it may also help out with soem of that missing torque..
very interesting post, i would like to see where it goes...
