Ready to measure the tolerance at 4 cylinders at 20mm,60mm & 100mm as shown in the picture above,at the points where the line of the cross cuts the line of the circle.
A very important issue is the finish roller after grinding!
The first thing to pay attention is what metal piston springs the kit includes the ones we got to order.
Some companies to give along with the box that most simply throw in a tip and others need to communicate with them.
For example, the CP Carrillo gives ready to read the editing process and understand that not just go on the block grinding and say make us a shining!
Each kit has its own c we must equip base!
GAS NITRIDED, CPN, CPN2 AND R8GNHD PISTON RINGS
To identify a gas nitrided top ring the entire ring will be a light gray. These instructions must be followed for maximum ring
seal. A torque plate must
be used unless the bolt holes are not part of the cylinder. The first stone is a 525 (220 grit) stone, done until there is .001
” left from final bore. The
bore must be round to .0002”, checked 360 degrees from the bottom to the top of the bore. Then switch to a 625 (280 grit) stone
, 50% load until
.0002” is left from final bore. Then use the 625 stone at 20% load to final bore size.
DUCTILE MOLY RINGS
To identify a moly top ring look for a silver-grey plated finish with black phosphated top and bottom surfaces. If there is a
dot on the flat side of the
ring, make sure it faces up. Rough hone cylinders to within .003, intermediate hone to within .0005 with 220 grit and final h
one with a 400 grit and
a 10 to 12 RA finish with a 20º to 22º crosshatch.
CHROME RINGS
To identify a chrome top ring the face will have chrome plating, the top and bottom of the ring will be a reddish-brown. Chrome
on any of the rings is
not advisable with nikasil bores. These instructions must be followed for maximum ring seal. A torque plate must be used unless
the bolt holes are
not part of the cylinder. The first stone is a 525 (220 grit) stone, honed until there is .001” left from final bore. The bore
checked 360 degrees from the bottom to the top of the bore. Continue with a 525 (220 grit) stone, 50% load until .0002” is left
use the 525 stone at 20% load to final bore size.
ALL RINGS
The honing must be done slow to minimize heat build-up. No hand honing. Final bore needs to be less than plus or minus .0002” o
ut of round,
checked 360 degrees around the bore from the bottom to the top of the cylinder. This should be checked with a dial bore gauge.
The expertise of
your machine shop is critical to the proper finish on your block bore. When you receive the block back from the machine shop it
will appear clean,
the block still needs to be cleaned. There could be material trapped in the honing grooves of the block that are not visible.
Failure to clean the block
could lead to premature ring wear and blow-by
Pistons are manufactured from extruded high silicon, enhanced 4032 alloy (with additional Cu, Ni & Mg) that has low thermal expansion, excellent wear resistance and higher thermal conductivity. Pistons with this alloy have withstood up to 42psi (2.9Bar) of turbo boost, with alcohol, without any problems
"Phosphate dry lubricant" coating is applied to protect the rings against "micro welding" and enhance lubrication on the skirt/cylinder area.
Piston Rings are manufactured in Japan with the latest technology for high performance applications.
TOP RING
B = 1.00mm (0.039”)
Share = Barrel Face (BF)
Material = SR34 Steel
Surface Treatment = Gas Nitrided
2ND RING
B = 1.20mm (0.047”)
Share = Taper Underhook (TUH) Napier Desing
Material = CR10 NPR Nippaloy B
Surface Treatment = Phosphate
OIL RING
B = 2.80mm (0.110”)
Share = Flexvent (Nifflex-H)
Material = SR34 Steel (Rail)
Material = SR21 Stell (Expander)
Surface Treatment = Gas Nitrided (Rail)
Surface Treatment = Phosphate (Expander)
Oil ring installation
Custom Tgs adapter preparation to fit RB26DETT intake manifold & itbs
