sjbsuperman1425 wrote:the line i speak of was on the "Bracket" with all the vacuum lines that i removed. there is also a hardline that was right above the rear heater hose hardline?
ey guy if im not wrong about this...im sure that most those vacuum hardlines are just brackets that keep it steady where it leads...
and for the comp housing that T's off with wastegate actuator...i just did a direct connect....it used to be like this
.................|------Wastegate actuatorTurbo-------|.................|-------Turbo Inlet pipe(intake filter pipe)
(...'s are space >_> i cant make macros on this forums? its sposed to look like T'd off lines)
i blocked off the inlet and direct connect the turbo and W.A.
