capowered240 »
https://forums.nicoclub.com/capowered240-u27587.html
Mon Oct 06, 2008 3:47 pm
I found this and thought that it could help anybody doing a ca18det to ca18de harness conversion. I know it is just the pinouts though. Hey, it's a start.
ca18de harness setup:
101 102 103 104 105 106 107 108|01 02 03 04 05 06|13 14 15 16 17 18 19 20 21 22|33 34 35 36 37 38 39 40|109 110 111 112 113 114 115 116|07 08 09 10 11 12|23 24 25 26 27 28 29 30 31 32|41 42 43 44 45 46 47 48|
ca18det harness setup:
101 102 103 104 105 106 107 108|01 02 03 04 05 06 07 08 09 10|0|21 22 23 24 25 26 27 28 29 30|41 42 43 44 45 46 47 48 49 50|109 110 111 112 113 114 115 116|11 12 13 14 15 16 17 18 19 20|_|31 32 33 34 35 36 37 38 39 40|51 52 53 54 55 56 57 58 59 60|
pinouts:
det/de/color(de loom)/explanation
1 1 black/red ==Coil 12 2 black/yellow ==Coil 23 8 red/blue ==Coil 35 11 blue ==boost/power control solinoid valve6 10 blue/yellow ==A/C relay I neeeds them extra kw's so take it offf!!!!!7 3 red/white ==Tacho Drive Output To Auto8 ==Variable intake butterfly Control sol.10 6 black ==Ground11 9 red/white ==Coil 416 4 black/yellow ==ECCS relay (Earth=on)17 ---------------------- Injector Pulse relay (for trip computer. Not on exa)18 104 white ==fuel pump relay Earth = on20 12 black ==ground23 28 white ==Knock/Detination sensor26 16 black ==AFM pin B Air Flow Meter27 15 white ==AFM pin A Check these two AFM pins… they could be backward.. But I think they're right28 17 yellow ==Coolant Temp sensor29 18 white ==O2 sensor30 20 black ==20 +30 Sensor Earth32 ---------------------- Check connector: These are for Nissan to hook up their33 ---------------------- Check connector: Diagnostic Comp's…. Who needs them?37 27 green/yellow ==AFM Pin D38 19 white ==TPS potentimeter TPS (throttle Positioning Switch/Sensor)41 21 green/black ==CAS 180 deg Crank Angle Sensor42 22 green/yellow ==CAS 1 deg inputs43 35 green ==Start Signal44 36 orange ==Neutral Switch45 37 black/white ==Ignition On46 41 blue/yellow ==thermo control for AC47 ----- ---------------- Check connector48 38 white/black ==TPS battery output49 47 blue ==Battery from ECCS relay ignition coil relay50 40 black ==Ground51 31 breen/black ==CAS 180 deg CAS Back up52 32 green/yellow ==CAS 1 deg CAS Back up53 33 white/blue ==speed sensor54 34 red ==TPS idle55 --------------------- Ambient Air Temp Sensor None on Exa56 --------------------- Auto control. Auto? Yeah right!57 44 white/blue ==TPS FULL!!!! the way it should always be!!!!!!!!!58 46 black/red ==Battery unswitched59 39 blue ==Battery from ECCS relay60 48 black ==Ground101 101 white/shield ==Injector 1103 103 black/shield ==Injector 3106 113 yellow/red ==AAC Auxillary Air Control Solinoid valve thingy107 107 black ==Injector ground108 108 black ==Injector ground109 109 black/red ==Battery to/from ECCS relay110 110 yellow/shield ==Injector 2111 102 orange ==Fuel Pressure Reg.112 112 white/blue ==Injector 4115 ----------- Heater output for O2 sensor Exa's only have one wire for O2 sensor.116 116 black ==Injector Ground
