Post by mazikowski » https://forums.nicoclub.com/mazikowski-u67058.html Sun Aug 24, 2008 1:12 pm
Post by boost_boy » https://forums.nicoclub.com/boost-boy-u2853.html Sun Aug 24, 2008 2:29 pm
You can use the 1.8l pulsar's starter on your ca18det. You are fwd, correct? Anywho, you can use either or.mazikowski wrote:What starters will work for the CA18DET? Would the CA16 and CA18 pulsar starters be fine, or is the tooth count different on the flywheel?
Post by mazikowski » https://forums.nicoclub.com/mazikowski-u67058.html Sun Aug 24, 2008 6:46 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
