ca18detgabby wrote:...for the 2 seconds it would take to check the ECU....... I would save my 21 bucks and check the ecu just for ****s an giggles as it doesnt cost anything and is a simple fix.
After i hooked up my knock sensor last week, i check the ECU codes. Then i checked them again the next day after driving it a while. Still getting no codes.
ca18detgabby wrote:Ps if you have tuned the car to run these items....... was there a point where it was running ideal? just curious if this is a first test or something that is just now starting to have issues.
Basically first test. Ive been sorting through my running problems since i finished putting the motor in last November. I just keep eliminating one problem after another, it just seems this is the last one, and the hardest one....
ca18detgabby wrote:I have never heard of running a stanza ECU.......... why?
Its only on the SOHC KA. Nothing to do with the CA18. Just making the point that im not new to ECU tuning, thats all.
bias wrote: Has anyone changed there alternator? I know we have been thinking coilpacks but the alternator runs the car. I noticed when I use my lighter the interior lights die down. I don't have anything in my car but a boost gauge, timer, and factory heat/ac controls? What do you all think?
Not sure, but wouldnt you think that if the alternator has enough power to keep the car running and the battery charged, then it wouldnt affect the ignition, since all those components are seeing the 12V they require? And if your lights dim when you use an accessory, your alternator may not be putting out the voltage required? Only time my lights dim at night are when she wants to die coming down to idle, sputtering the whole time.
Today i was kinda thinking about my ECU tune as a possible suspect, but if no one else here has tuned their ECU, then thats probably not the problem. But im still going to check the fuel maps one more time.
What about heat range of the spark plugs? Im pretty sure mine are standard heat range of 6, but what about changing to a hotter plug?
