JNM240 wrote:
Yeah, its 22698-R2000. I just found it by putting it into the search bar. It came up as : "This is an un-categorized Genuine Nissan Part that you found by searching for the name or number." And was listed as out of stock 2-3 days. I got it in like 10.
So you have the sensor installed and working on your motor? I know which plug it plugs into, but that is now on the passanger side of the motor right by the ignitor, and looking at the FSM, it should be on the drivers side, right next to the turbocharger. I know the ECU sends a signal to it to open and close, but what circumstances does it do this? Is my not having it causing my fuel pressure to be incorrect during startup, both cold and warm?
Thanks for verifying the part number, was looking at the wrong place in the couresyparts.com site.
I mixed up things above and my sensor reply was ment for Hayakus13.
Either way, and please correct me if Im wrong, you are saying that you dont have the Vaccum sensor that is usually next to the Power Transistor installed in your car? Isn't the FPR vaccum feed supposed to come from this sensor?? "Pressure Regulator Control Solenoid Valve" or some like that, right? Dunno what would happen if this fails or is fully removed. I just know the line that is supposed to come from the intake is not hooked on mine as Im running custom piping and never figured out where to put it.
I would check that and double check the FPR again just in case.
