masterfubu wrote:Ok, first off, I have searched a lot of questions on the forum and these are the questions that I do not have answers to. Any help would be appreciated and if you have a link with the answers, please share.
I have a 1992 nissan 240sx 5spd. After much research I have decided that the CA18DET swap is the most economical way to get to my modest hp goal of 200 hp.
My questions are:1: Are engine mounts interchangable between the ca18det and the sr20det? Specifically, will Nismo engine mounts work?
2: Do any transmission parts from other engines, stock or aftermarket apply to the ca18det transmission? I am looking to replace the clutch and flywheel during the engine swap and I am having trouble finding the right components. I would like to use a light weight flywheel 10-12 lbs (any recommendations) and a slightly uprated clutch.
Thanks in advance,Chris
I question your searching abilities...
Just a few posts down, we have a thread titled,"installed proper CA NISMO engine mounts.."
As for the clutch, I typed in 'clutch' under the CA forum and came up with all these....
zerothread?id=104014http://forums.nicoc ... ?id=120286
As for flywheels... they pop up on ebay every now and then, but they are almost impossible to find. Personally, I don't know if I would want a really light flywheel with this motor....
