Hmmmm... I'm going to look closer today but like mentioned, I dont have the straight tube to the left. It's just a 90 degree bend. Would you by chance know exactly where that straight piece begins? I've looked around the mani and haven't found anything, will look again in some daylight.float_6969 wrote:That's correct. That tube on the left should connect to the 90° fitting on top of the oil filter. It's an odd size, reducing diameter straight hose. Ultimately it ends up connecting to the back of the intake side valve cover.
