float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Aug 13, 2005 6:34 am
Cliffnotes:If your CA18DET didn't come with the engine mount brackets, you have three options;1. Use CA18E(T)/CA20E brackets AND mounts.2. Use CA18E(T)/CA20E brackets, and bolt/weld a plate onto the bottom of the mount between the two holes and drill a hole in the middle. This will allow you to use the NISMO CA18DE(T) motor mounts. 3. Go to the SXOC site and get the correct CA18DET brackets from there. Expect shipping from the UK to suck though.
