Let me personally give you some advice, go to your autozone or nearest autoparts store and buy you a manual for a Nissan pulsar that covers the 87-89 model years as well. Let this book or the nissan sylvia/180sx fsm that is found online somewhere on NICO or with the help of some of your fellow CA members be your guide to some of the basic questions you are asking on this forum. I'm telling you to do this because you are going to get flamed or be told to use the search button because some of the questions you're asking has been answered more times than I care to remember. So please, do a little home work on your own and search the internet as well as NICO's archives for information because believe it or not, the information you seek is available. And don't mistake my informing you as a verbal spanking because that is not my intent. I have no issues with you asking questions, but it is part of the moderation team's responsibility to advise you as to the whereabouts of such info; especially stuff that has been rehearsed 1.9million times . And to those members that do know the answer, though it is very simple for you to just give an individual the answer, everyone on this forum must do their own homework if they want to learn about said engine. It is imperative that you not spoon feed anyone without 1st instructing them try searching for the information they seek. This will allow the forums to stay clearer for members with more challenging questions and free-up some bandwith as well.zero_gripS13 wrote:trying to put together a list of parts to get for maintenance for when i get my motor...so far i got. engine gasket set (nissan doesnt carry it, but ill try.. if not will ca18de one work form autozone?)water pumpintake manifold gasketnew vac linesspark plugs (does it even have plug wires lol)radiator hosestiming belt, idler, tensoner
can u list some other parts i should replace .. also can someone provide a part number for the oil pump( any suggestion on where to get, does autozone carry one..i dont want a cheap ggeneric one i want one that i can trust)also does the engine gasket set come with everything needed..
basically add anyhting i will need/ or am forgetting...also i couldnt figure our the exhaust gaskets i need..
thanks..
***please include part numbers and location i can get from if u dont mind.. thanks
Oh yeah BTW "Use the search button" LMAOzero_gripS13 wrote:trying to put together a list of parts to get for maintenance for when i get my motor...so far i got. engine gasket set (nissan doesnt carry it, but ill try.. if not will ca18de one work form autozone?)water pumpintake manifold gasketnew vac linesspark plugs (does it even have plug wires lol)radiator hosestiming belt, idler, tensoner
thanks..
Did you search the archives as well? It's funny, I was a nub on this board about 5 months ago, and now I am answering tons of questions people have. 90% of everything I've learned about this motor I got from the search button on here.zero_gripS13 wrote:there is nothing to search on this forum... no information besides whats on the stickies.. i have read every thread on the ca forum.. i loked through the stickies but i honestly am not sure what parts is need.. plus alot of the times it says ca18de and im not sure if itll work on the det...
Personally, I am replacing every single gasket/seal in the motor. I had to do a bottom end rebuild and I figured I may as well have it in tip-top shape. Remember, a lot of these motors have been sitting in a junkyard for 10+ years baking in the sun. The rubber will be dry-rotted and a lot of the seals may have dried out and cracked.zero_gripS13 wrote:also i dont see what the problem is.. u guys know alot more about thsi engine than i do.. so u can give me some of the parts that definately are a good idea to change...
You're not going to find the part # for the DET oil pump because we never got the DET. Just get an OEM oil pump for an '88 Pulsar NX SE from Nissan. Here, I'll feed you a cheap place for an oil pump.... http://www.trademotion.com/par...gid=1zero_gripS13 wrote:also.. i can find a part number for the det oil pump... if i cant find one what kind can i use.
And don't be such a hard-@$$ about it! We are obviously trying to help you because we are answering your posts. But don't get all hasty because our replys are not exactly what you want to hear. Knowledge costs in one way or another and searching for the information you seek is and I say again "IS" on NICO and most of the info you need is right up in the stickies. With a CA18DET, you will now be requesting most of your hard and soft parts for a 1988-89 nissan pulsar with 1.8l DOHC motor and please don't forget this.zero_gripS13 wrote:what archives???
im not asking to be fed.. im asking for siggestions and advice since im new to the motor.. i plan on replaceing all hose vac line due to the dry rotting...
also i want to get a engine gasket set to replace all the gaskets, but im not sure what included and what ot included (and can i use the ca18de one form autozone)
