CA18DET hard to start
[email protected]
Car: 1990 Nissan Silvia S13
I have a real general question. Whenever I start the car, it appears that it is difficult for the car to turn over, but once running, it's fine. I have asked people their thoughts, and have heard everything from the battery to ECU to ignition.
To give you an idea of what it is doing, the car acts like it does not have enough power to turn it over, and I have to press on the gas pedal to help it start.
So far, I have purchased a Blitz Access ECU for it, changed the plugs, oil, you name it, it's been done.
Any ideas, because I am out of them????
flohtingPoint
Car: 2004 Z16 Corvette Z06
Has it always done this, or is this a recent thing. Check your idle screw on your throttle body.
Pumaking
did you check the starter
float_6969
Pumaking wrote:did you check the starter
From your description, I agree. They DO get weak as they age and don't turn the car over as quickly. I've seen starters get to where they will turn the motor, but not quickly enough to actualy start it. They will kind of surge too. Like when a piston gets to the top of the compression stroke, it doesn't have enough balls to keep it going.
biosehnsucht
take it apart, clean it up, possibly use fine grit sandpaper to sand down the brushes, and relube the parts that need lubing, put it together, should be brute force.
I wish I had had a camera on hand to take pics of a walkthrough when I did mine..
also, check battery terminals, if there's corrosion it limits the amount of power the starter can pull from the battery..
[email protected]
biosehnsucht wrote:take it apart, clean it up, possibly use fine grit sandpaper to sand down the brushes, and relube the parts that need lubing, put it together, should be brute force.
I think that is what I am going to do next. If that doesn't work, who knows.
fallen180sx
Car: 90 Sil80
imo, it sounds like when i blew my headgasket.. it would take a long time to crank, but when cranked it ran fine. but note that he didnt say it ran hot when cranked fine either
