Ca18det Flywheel Parts #
turbo_blitz21
Car: JDM FD
Hey I have searched everywhere and I need a flywheel parts number! Please help
c-rad
Car: 1991 Nissan 240SX w/CA18DET
You're not going to find a RWD flywheel in the US.
sdtouge
Car: 1990 240sx coupe
you probably dont have a clutch yet, since you are still in your build but places offer lightweight flywheels (takaira.net i tihnk it is) and also you cna use a sr flywheel if you use sr clutch and sr starter , just search in the archives there some thread about it somewhere.
float_6969
If you don't have a flywheel, you'll probabally have to go the aftermarket route. You won't find one from Nissan. The easiest route is to get an aftermarket (Fidanza) flywheel, SR/Maxima clutch, and a specific CA starter. It's called a gear reduction style starter and the difference is that they don't have a nose cone. This will allow the starter gear to clear the teeth on the flywheel. You can use the stock starter, but you've got to grind the nose cone part of it down.
pulsar gtr
Car: NISSAN VEHICLES
you can get the ca18de PULSAR flywheel, it is the same diameter and the starter from the pulsar with ca18de will work fine.
I do prefer the pulsar flywheel as it is almost half the weight of the regular ca18det flywheel.
But if you still need a ca18det flywheel, I believe I have one sitting with the rest of my ca18det junk lol, let me know if you want it.
Good luck,
PULSAR GTR
turbo_blitz21
Car: JDM FD
Well see the reason I needed the part number is cus we have a million flywheels at the shop and one of them is mine and i dont know which one HEH!
mbmbmb23
I know there is a thread somewhere but I cant find it.........is there a definitive list of flywheels that WILL bolt up? (RB, VG, etc.) because I see some nice used OS GIKEN clutches on ebay all the time.
thanks,
-M
NeedCAforS13
Car: CA swapped S13 coupe
sr20det clutch and flywheel. CA18ET s12 200sx (1985) starter. dremel to the bellhousing. Fits fine! SEARCHHHHHHHH there is a thread about how its done.
Sean
tyrannix
Car: go big or go home
i have one sitting in my shop, ill see if it has a legible part number tomorrow for you
NeedCAforS13
I have one in my garage, no part number that I can see.
Sean
turbo_blitz21
Car: JDM FD
Oh I did search btw nothin i needed cus it was asap kinda stuff. But its cool thanks for the help I didnt go back to the shop but hopefully i will find that **** tommorow.
