Bro, just buy you another motor to save yourself a major headache. It will be worth the money you're about to spend and headache you're about to encounter. You're not the 1st one to get a crappy motor and you won't be the last. But at least give yourself a fighting chance by getting a motor that you can put in your car and enjoy and use your busted motor for a project whereas you can take your time and build a stout beast.tx_widebody wrote:Ok here is the situation, I just found out that i have a ca18det block and a 1.6 head, will this work?? And i have 1.6 pistons and rods and i need to buy ca18det rods because i already have the ca18det pistons ordered, so if someone knows someone who has some 4 sale that would be great. And one mor thing how can u identify if i have a ca18det crank, the guys at the machine shop have no idea wat i have got??Umm i think that is about it thanks for ur help!!!!!!!!
+1 for that...boost_boy wrote:Bro, just buy you another motor to save yourself a major headache. It will be worth the money you're about to spend and headache you're about to encounter. You're not the 1st one to get a crappy motor and you won't be the last. But at least give yourself a fighting chance by getting a motor that you can put in your car and enjoy and use your busted motor for a project whereas you can take your time and build a stout beast.
Dee
If you already had the work done, how much is left. A motor will cost you around $700 with all the goodies attached and of course a little less stripped. The problem is that people are picking-up some crappy motors where the bottom end is done or nearly on it's way out the door. The motor in mu old lady's sentra hass been a bee with an itch by eating cranks and bearing for lunch. Luckily for me, bottom end issues are resolved.tx_widebody wrote:But i have already had all the work done to get this thing going and i am so close. But if push comes to shove how much do u think i can get just the motor for, no transmission or harness?
