lol it is a dodge....... he it is faster simply because it is still running. he could get behind it and push and it would be fasterTwo-Fortee wrote:So its faster than your trucks that weigh close to 4 000 pounds? Sweet.
Ya, but it ain't got squat on my 4:11 geared 450 hp 3200 lb 55 Chevy :PTwo-Fortee wrote:So its faster than your trucks that weigh close to 4 000 pounds? Sweet.
Thanks, and don't worry until this thing gets all the bugs worked out and painted etc - they ain't gonna be much of any upgrades. Once I stock up a little cash I'm thinking of going with a front mount intercooler. There is plenty of room with the coupe front bumper for one. I've not touched the factory settings on the boost nor plan to for awhile. As for the Ecu, I've got Nistune and I only plan on changing up the injectors when they go bad. Regardless it will be wideband tuned once those go in.boost_boy wrote:Congratulations on getting your swap up and running. It should be a fun car to drive, but the same rules apply: No boosting above 12psi on stock system, no advancing the timing to get some extra power, no upgrading injectors without getting ecu upgraded to accomodate, blah, blah, blah. Other than that, you should be able to have some fun with it.............
Dee
My gauges are mounted on the driver's side A-pillar using a gauge pod from a civic and some minor mods.campground man wrote: Any ideas on gauge mounting in a B12?
I hope mine lasts more than 10 days!boost_boy wrote:It's so cuuuute ! That takes me back 10 years to when my first DET swap resembled yours, less the way the air filter sits. The engine had around 10k miles and looked fairly new. I would eventualy destroy that engine 10 days later. Happy boosting...............
Dee
really!? then i feel a lot better that mine laster a few months before the Tbelt snapped!boost_boy wrote:It's so cuuuute ! That takes me back 10 years to when my first DET swap resembled yours, less the way the air filter sits. The engine had around 10k miles and looked fairly new. I would eventualy destroy that engine 10 days later. Happy boosting...............
Dee
I think it's the 1992-95 model. I just never really paid much attention to the year; just got 'em and modded 'em.campground man wrote:
By the way Dee, on the gauge pod you modified, what year of civic do I need to order the gauge pod for that I can modify to fit my B12?
Is a guy on nicoclub.com that sells urethane bushings for pulsar se sways, just do a search on there. Yes I'm a US guy. In the US sentra's came with tiny sway bars, I got a set from a Pulsar Se to upgrade my suspension.Liquid_Neon wrote:
hey campground man, i notice ur sig says ur pulasr has urethynes and a sway bar upgrade(?) Are you a US guy? whered u get that stuff, i cant find anything this side of the ocean!
