CA18DET AWD ECU pinouts
NX EXA
Car: 89 Pulsar NX SE project
87 Pulsar NX SE parts for project
Are there any members in here that are running the CA18DET AWD? I need the ECU pinouts, there are a few wires that I don't know where they go. If anyone can help me out that would be great.
datsunboy
Car: Datsuns
My guess is they are the same as the RWD ones.....but thats my GUESS.....I can't see why they would be different.....but it would pay to be sure.
boost_boy
NX EXA wrote:Are there any members in here that are running the CA18DET AWD? I need the ECU pinouts, there are a few wires that I don't know where they go. If anyone can help me out that would be great.
There's a couple of us that have FWD casr that are powered by the AWD CA18DET motor. But unfortunately, none of use the JDM stuff. Two of us use a standalone engine management and the other two are using CA16DE ecu's remapped by Jim Wolf Technology. The ecu for the AWD will be very close if not the same to that of the RWD units. You'll just have to download the S13 FSM to see computer and wiring information.
What are you trying to do? Is your harness cut and you're trying to splice something together? If you don't know nissan wiring, don't waste your time. Just get an S13 CA18DET harness and go from there.
Dee
nismoplsr
or
i have a complete spare CA16DE wiring harness that clips right onto the CA18DET and to come up with the CA16DE ecu reprogrammed for DET is easy enough.
NX EXA
I am aware that the wiring is the same as the FWD and RWD. I have an AWD gearbox that I plan to make use of but there are 4 extra wires on the ECU. I was hoping someone was using an AWD gearbox CA18DET and had a wiring diagram of the ECU so I could find out what these 4 wires go to.
datsunboy
Car: Datsuns
what are the 4 wires? what pins do they go to e.t.c.?
pulsar gtr
Car: NISSAN VEHICLES
Let me know which plugs or wires you are looking for, I got a complete AWD harness and ecu, I can trace some of the wires.
Also, if you are interested in the AWD wiring harness, I can sell it to you.
GOOD LUCK,
PULSAR GTRRafi
NX EXA
The extra wires are pin numbers 13,14,15, and 113.
Rafi, aren't you using the SR20DET? The wiring is different correct? Also, I thought you sold your Pulsar, you still have it?
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
What was AWD with CA ?? i thought they only came in Exa's and Pintaras as FWD..
boost_boy
rexhunta wrote:What was AWD with CA ?? i thought they only came in Exa's and Pintaras as FWD..
The nissan bluebird which is the same as your pintara or USDM nissan stanza, but with an AWD set-up.
Dee
pulsar gtr
I do still have my PULSAR, and I am using a ca16de JWT ecu, but I have an extra AWD harness and ecu that I got off an AWD engine a while back.
I need to get the piston rings replaced but I haven't had the time to do it, as I am converting my Z32 to twinturbo and getting teh body repainted. I will try and get you the wiring tomorrow as It is at the shop and first thing after work tomorrow I will drop by there and get the info for you.
PULSAR GTRRafi
datsunboy
Car: Datsuns
The AWD motors came in the Bluebird SSS Turbo Attessa's
rexhunta
MY10 Forester X LE
datsunboy wrote:The AWD motors came in the Bluebird SSS Turbo Attessa's
Wow.. what year roughly was that ? cause i remember the SSS Blurbird with the fully sick CA20 or L20.. just did not know that they ran an AWD blueturd.
It's kinda like finding out they made an AWD Mitsubishi Cordia too..
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
The extra wires are pin numbers 13,14,15, and 113....
Here's what I know.
13: Exhaust Temperature Warning Lamp14: Radiator Fan 1 trigger15: Radiator Fan 2 trigger113: ABS Solenoid.
I got this wiring diagram back in 1993. This is translated information, and I expect this is accurate information.
Regards,Chris aka shoey.
NX EXA
Good deal, thanks Dattodude.
