typhoonslippery »
https://forums.nicoclub.com/typhoonslippery-u77634.html
Sat Jun 28, 2008 12:33 pm
I have a S13 Silvia with a CA18DET in it and I am having a weird issue where I an fire up the car and it will idle well but when I touch the throttle at all the car will drop revs instantly and want to die but if I let off the throttle it will catch and idle again. I can tap the throttle lightly (10%) and have it climb the revs but tap tap tapping it but if I press on the throttle any more than that it will want to die (fall on its face).
Any ideas? I have replaced the fuel filter/ignitor/coil packs and harness/re-did all engine and engine bay grounds/ tps and coolant temp sensors
