CA swappers, is there a plug on the KA harness for the knock sensor?
themadscientist
I have never worked on an originally KA-powered car with a CA going in and I was curious what are you guys doing for the knock sensor?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
themadscientist wrote:I have never worked on an originally KA-powered car with a CA going in and I was curious what are you guys doing for the knock sensor?
The KA knock sensor comes out of the harness where the coolant temp sensor and TPS sensor is. For the CA, I am running the knock sensor straight into the main harness where it comes out by the plugs near the battery.
Dattebayo
This is for a 1993 S13. I dont believe there is a knock sensor.
c-rad
2BN_S13 wrote:This is for a 1993 S13. I dont believe there is a knock sensor.
Umm....the KA24DE's have knock sensors dude.
themadscientist
ok, where does the KA knock sensor wire meet th CA harness. Is that one of the wires that must be spliced under the dash? I keep waiting for someone to say "search newb"!
c-rad
themadscientist wrote:ok, where does the KA knock sensor wire meet th CA harness. Is that one of the wires that must be spliced under the dash? I keep waiting for someone to say "search newb"!
I don't know, we don't use the KA knock sensor with the CA. We use the CA knock sensor. This is where I wired mine...
In case you can't tell, I ran the knock sensor from the lower harness up into the main harness. It's not like that now though...I seperated it from the lower harness altogether.
Pumaking
off all the people, you the moderator should know to search you oldie
if it helps heres what the search button looks like.
btw its in your top right hand corner.
float_6969
LOL, Ok give him a break guys, he's not usually in the States, so he's a little confused. You know, driving on the correct side of the road and all...
Anyway, it depends on what motor S13 you are working on. The KA24E's (like mine) didn't have a knock sensor and so lack the appropriate wires under the fuse box for the knock sensor. Since I had the CA lower harness, and it had the plug for the knock sensor, I just separated it out of the lower harness and the sheilded wire out of the main harness, found the correct plug, spliced it all together, and plugged it in.
c-rad
float_6969 wrote:LOL, Ok give him a break guys, he's not usually in the States, so he's a little confused. You know, driving on the correct side of the road and all...
^^^^^^^^ That's what I was trying to say...
