hello there... im pretty much new here and i must admit, i need some input from yall.
i just got done with CA swap and there is quite a few problems that ive noticed. One major one, the tach dooes not give any output . checked all wires and everything seems in place...am i over looking something? :/
sencondly, whenever i power off , my starter relay "clicks" and will only stop when i unplug the MAF sensor or the Relay itself. tested it with a different relay and same results. Short?
plus i need some additional advice about fueling. I can never get a def answer but ii was wondering are 440cc injectors are good enough to withstand with the T28 turbo w/ 12psi. fyi i upgraded the FPR and pump as well. again, any info is greatly appreciated. also CONSTRUCTIVE criticism
